free website stats program excessive amp draw from headlights | Harley Davidson Forums
oldschool43
91 ultra which has dual headlights, shows normal current draw until headlights are turned on.....passing lights,radio etc have no effect...if i unplug 1 headlight at a time{either one}there is no negative effect...please help
depending on rpms
Sounds like your going by the dash gauge. Measure the voltage at the battery with a quality handheld meter and you probably won't see those numbers. Zero to eight volts?,,, even a carb bike would probably not even run.
