1996 and later, to about 2006, will work. However all the gauges would have to be changed. The radio, if you have it,may or may not fit the hole in the inner fairing. You would have to get a mechanical front wheel speedometer. Your tranny does not have the VSS hole for electronic speedo. You would need outer fairing, inner fairing and associated mounting brackets. You would also probably need to do some re-wiring. Quite a project, but it can be done with time and $$$$.
tourbox
