C chuck60 Active Member Aug 8, 2011 #1 I guess it's normal to have a different sound at the air filter when you change to the SE air intake, you can here it sucking in air.
D dbmg Guest Aug 8, 2011 #2 Tank has you covered. On old bike I had a 6" round completely exposed air filter update on it. It make quite a bit of intake noise. Like in the old days when you flipped over the air cleaner lid on a 4 barrel carb....Remember :laugh
C chuck60 Active Member Aug 8, 2011 #3 The slip on pipes I'm getting are RC Components from Harley, are they a OK slip on to use with the TFI.
G glider Veteran Member Aug 8, 2011 #4 Any slip on can be used with the TFI.Your choice is a good muffler.
N Nightowl Account Removed Aug 8, 2011 #5 I had forgotten about that. What a great sound. Almost as good as a playing card in your peddle bikes spokes.
