Ok it took me most of the day but it's done, all the oil's changed, the neck greased, and check all the nut's and bolts that needed checked and i think i saved about $225.00 The belt and clutch both seemed fine.
The best part of doing it yourself is that you KNOW it was done.:s
I still have a loud noise coming from the transmission after putting in a heavy gear saver oil, but they tell me that's just how it is.
[ Also I'm curious on these models that have grease fittings on the neck, do they fill up the "entire" neck with grease ? ] If so that must be a mess come time to change the bearings.
