I'm headen to northern Michigan next week with the wife and a full load on the flhtcutg.What tire pressures do you run on the rear tires with a full load ? Thanks BP
I would go with the sidewall recommendation wich changes from one manufacturer to another. Also pay attention the weight limit on the sidewall. Dont forget that when the tire gets hot the pressure increases in them. Safe trip, Take pics.
Owners manual will be good if you have stock tyres fitted the max pressure marked on the sidewall is a do not exceed pressure not a pressure to apply the tyre manufacturer knows more about their tyre than anyone else so their recommended pressure for your application is the one to use
tyre pressure is a critical safety issue on a motorcycle just get it right
The tire specs say 26-44lbs.I've looked for tp's on the Dunlop site with no sucess.I'm looking for tire pressure readings that will give me the numbers for a passenger and luggage combo.Thanks for any info. BP
