free website stats program Forward control brake arm | Harley Davidson Forums
cyborg
I have forward controls on my Dyna, (dealer installed). And I want to put a larger brake pedal pad on. The brake pedal has the rubber pad molded right on to the brake arm. Anyone know if it still has a hole drilled in it like the old style?
If I remember correctly when I did mine, I am pretty sure it does, but of course the only way to find out is to take it off.
If you take off the pad, which should be somewhat easy, it is easy enough to put on. I know you can buy new brake pedal levers to which are nicer looking, so you may want to go this route as well. It is easy enough to take off the existing one and replace it. Of the installs the brake pedal side was the easiest.
I replaced the stock rubber pad with the black diamond series upgraded pedal. There is a single hole in the chrome lever through which the new pedal is screwed in.
