I have an 07 FXD and was wonder if any one know how to do this upgrade. I would like to do this myself if possible and how much it would cost?
Are there any web sites with step by step instructions?
Thanks
pacman1999
Two and a half years ago, I was asking the same question. I desperately wanted forwards, but had no experience doing any work on my Harley and was scared to get a wrench anywhere near it.
You have several options to chose from to purchase your forwards. Of these, the most popular options are between the Harley forwards or Kuryakyn.
The thing which complicates the forward control install on the Dynas is the mid control shifter shaft which runs through the primary. In order to remove it intact, you must remove the inner and out primary covers. Most elect to either leave the shifter shaft in place, or cut it so it can be removed.
The Kuryakyn Forwards are the easiest to install because you can leave the mid control shifter shaft in place, install the forwards, and use a supplied decorative chrome cap to cover the remaining shifter shaft.
The Harley forwards do not seem as easy at first glimpse. When you open the box and read the instruction sheet, it will refer you to the service manual for steps to remove the outer and inner primary covers. This is very intimidating. Many guys have found ways around these complicated steps which can make for an easy install of the Harley forwards, even for a novice wrencher.
You can install the Harley forwards and still leave in the mid control shifter shaft in place. A decorative cover for the shaft is available. You can also remove the shifter shaft without removing the primary covers. This requires cutting the shifter shaft. I selected this method for my install and it went great.
Here is a link from the self help section which will provide you a lot of info.
Dyna Forward Controlls - Archive - Harley Davidson Community
You can go to Kuryakyn's website to view their forwards. They offer installation instructions on the site in pdf.
Feel free to ask any questions and hope this helps.
