Good afternoon fellow HD riders. This is my first post, but I've been reading and searching the forums for some time now. Hopefully someone can help before all of my hair falls out over this issue.
About 4 months ago, I purchased a '99 Road King Classic. My first HD, but not my first motorcycle. It had a smidge over 12k miles and was in great shape for its age. Motor ran strong and bike rode smooth. Its previous owner maintained the bike well. It has a stage one kit with Supertrapp pipes. No other mods.
When I got the bike home, just for good measure, I changed all of the fluids, purchased an HD service manual (PDF online copy) and checked the primary chain, final drive belt, tires, and shocks for proper specs and pressures according to the manual. On my first long ride out (Texas HOG rally in Beaumont) I put about 600 miles on her and noticed a rattle when going over small bumps in the road like railroad tracks, uneven pavement, city (EDIT), or speed bumps. It sounded like it was coming from the front end. I checked the front wheel bolts for tightness and they were all fine. After more riding, the noise not only became louder, but started happening not only over bumps but at idle while standing. I have removed the primary cover and listened while idling and don't believe it's coming from this area. I have idled the bike and had my wife give a listen and she can't seem to locate the source of the rattle either. She describes it as a license plate rattle noise, but I think it sounds like more of a solid piece of metal than that. It sounds like something is loose, but for the life of me, I can't find anything. I thought it may be a motor bearing (man I hope not) but all drain plugs were relatively clean when doing the fluid changes and the speed of the noise does not increase relative to RPM. It also seems when idling, the noise only occurs when I have the front brake engaged. It seems the vibrations are more intense when I do this causing the rattle.
I know this is rather vague, but I see there are some very mechanically inclined individuals on this forum that I hope can help me brainstorm this issue.
Thanks in advance,
Mike
Thanks in advance,
Mike
