free website stats program Front fender rubs | Harley Davidson Forums
Front fender rubs
Sglyde
Hi every one.Front fender rubes on voltages regulator cooler when i brake hard.2002 Super Glyde, stock fender.
There is a CO. in Phoenix called bitchinbaggers.com that sells an adapter to compensate for this. I am guessing that you did not buy the bike new, and the previous owners probably lowered it a bit. The adapter moves the fender so this won't happen. If the bike was not lowered, then this might work, but not sure. Good luck to you. And to the moderators, sorry if this breaks the language rule, but it is an actual company.
You can also fabricate a small bracket to reposition the regulator slightly higher. I did that on my son's Dyna... worked great.
