Not quite sure how to explain this... my 2007 FXDC front tire reacts more than I expected to road conditions such as some of the lateral lines in the pavement that run in the same direction as you are traveling. You can feel the tire 'pull' when it runs along one of these lines. And, when you run across bridges that have the metal grade in the middle, the front tire just feels like its all over the place. Is this typical ? Due to the thin front tire on Dynas perhaps or should I consider this a problem ? I bought my FXDC used from a dealer last year, it has very low mileage ... a little over 2k. TIA
