I have an '09 FatBob. This year was the first year it got ridden in the rain or on wet roads. The tail light filled with water until it hit the hot bulb and broke it. I drained the lens, dried everything out and cleaned all the contacts. New bulb and everything was working fine.
I was on a road trip and the same thing happened twice more in rainy weather. I just drained it out and replaced the bulb and everything worked fine until the next rain. It rained again on the last strech to home so when I got home I drained, dried and cleaned everything again. This time the taillight would work but no brakelight. I also now noticed the lens had a fine crack in it. Whether this was the original problem or it happened from dropping the lens on one of the bulb changes I don't know. I didn't mess with it anymore as I decided to order the LED tribar light.
Anyway, I just replaced the stock light with the new one. The only thing reused was the pin housing/circuit board that mounts in the tail light base. All the contacts were well cleaned before reinstalling.
Again, everything works except for the brakelight, whether applying front or rear brakes. Is there anyone smarter than I that can shed some light on where the problem may be?
Thanks
Thanks
