98 Evo 1340
Due to lifter failure, I replaced my old VThunder EVL-3020 cam with a new one (same part number) because I was pleased with the grind. I re-used the cam gear from the original 3020 so I didn't bother to pay close attention to the clearance between the pinion and cam gear upon re-assembly. I now have fairly substantial gear whine but had none before replacing the cam. I *suspect* this is due to differences between the centerline of the original outer cam bushing and the new one I had installed by a reputable local indie.
My question: Is cam gear whine something I need to worry about, or can I just leave it be without fear of serious repurcussions? The noise isn't bothersome.
Thanks!
Thanks!
