Remove your left switch housing. Then insert a small screwdriver between the bar and grip, and squirt some isopropyl (rubbing) alcohol in the gap. Work the screwdriver around the bar, and squirt some more. Then twisting the grip should start to break the adhesive and it will (hopefully) slide off. You can also use WD40 or other spray, but they leave an oily residue.
