free website stats program Had some work done | Harley Davidson Forums
Had some work done
Diverwes
Had a set of S&S MR103 cams with adjustable push rods installed along with A set of Rinehart slimline duals and an S&S air cleaner. Tuned with Power Vision
84.39 HP
102.36 Torque
Have to check the tune as i'm getting some ping under low load at 2500rpm 3rd gear
Wes
2013 FLHTK
Looks like a good bump in power. Are you using high test gas?
Good numbers, does the Power Vision have enough timing adjustments to correct the ping?
Good numbers
pump fuel 93
At first I was getting some ping in 3rd at about 2500 and 5th at 2500 under light load acceleration.
Tuner took about 1 hour of riding in auto tune and it runs like a raped Ape now.
