JOHNMOWCOP
Hello.
2010 FLHTK.
I want to rotate the handlebars towards me, this will lower the grips and also allow me to sit back a little bit. I am only looking at 2 to 3 ins of adjustment.
The problem is: When the bars' are rotated I will need to twist the clutch and brake levers the opposite way to give a straight pull on the levers. The clutch side is ok, but the brake side will not rotate enough because the brake reservoir banjo and nut foul the bend of the handlebar.
Is there a smaller banjo and nut available? Has anyone else had this issue?
Any help appreciated.
John T.
			2010 FLHTK.
John T.
