the draggin
I got this problem. The low beam terminal of the headlight plug is heating up and melting the plastic of the terminal plug. I checked for good ground and that seems OK. Voltage is in the 12VDC rage. Has anyone encountered this before? I'm not thinking its the bulb. It checks out as far as ohms goes. Running output voltage at cruise speed is about 13.75VDC. That's in the acceptable range as well. Thanks for any help in advance.:newsmile091:
