baldharleyrider
On way home from work last night and head light went dim. When i would switch the hi beam off it would go dim but would never go out. If i switched the hi beam back on it would be bright like normal for a bit but then would go dim again. Got home and checked battery had 12.5 with bike off and with bike started it would jump up to 14.5 when reving it up. my question is do i need to go ahead and check regulator and stator, if the battery seems to be charging fine? Checked the bulb and it had a burnt spot on it. Replaced it. Everything else seems to be working fine tail light is not dim turn signals are bright and the radio works fine. 2003 road king
