kemo R.I.P Jan 19, 2009 #1 When you change cams and air filter and rejet the carb and use free flowing mufflers do you have to change the spark plug heat range
G glider Veteran Member Jan 19, 2009 #2 It shouldn't be necessary unless you have a problem with plug fowling because of the cam choice.
