'92 FXRS Low Rider. Put on taller handlebars, so I need to re-route the clutch cable. Problem is I can't get the cable loose from the clutch lever housing. Is there an easy way to do this ? My Harley service manual just says to pull the pivot pin in the housing, but can't seem to pull the cable out enough to run it throught the slot in the housing ? Let me know if you have any suggestions, Thanks
