I have a 2010 FLHTK that is less than two months old and 1800 miles on it. The other day I returned it to the dealer for a rattling/banging noise in the primary case. The dealer confirmed the noise and said that it is probably the compensator nut. They took the bike in, disassembled the primary and did not find anything wrong. After putting it back together, the noise was still there. They took it apart again, compensator, clutch, everything and called HD Tech Support with spring measurements and whatever other info the dealer provided. Tech Support apparently did not have any solution to the problem other than to suggest that I switch back from Syn III in the primary to Formula +, which they did and gave the bike back to me. Well obviously the noise is still there and I am scheduled to bring the bike back in on Monday. Any suggestions would be greatly appreciated.
Thanks in advance,
John
Thanks in advance,
John
