free website stats program help | Harley Davidson Forums
help
blues821
07 Road KIng cranks butr will not start ......no spark......
ok, I've got spark but no fuel
More info needed.
Carb or fuel injection?
If fuel injection, do you hear the fuel pump prime when you first engage ignition/run-stop switch?
Whatever else you can determine...
Good luck,
Rich P
Well I got it fixed....First I checked for spark which I had . Then I pulled up the codes and all that was there was po131 & po151 .So at this point I start looking at fuel and this is how I fixed it when I released the quick disconnect on the fuel tank I took a small philips screw drive and operated the ball check a few times when I put it back on the bike fired right up and has been fine all day......:newsmile093:
