David Maloof
I have a 97 road king injected..wont start cold without using the throttle..wont stay running cold without using the throttle..runs rough midrange..runs very rich..new plugs..running out of ideas..please help
Thank You Craig for pointing that out to David. As said in the past most problems with Harleys are do either poor guidance or ignorance when trying to repair bikes. Always start at the simplest common sense approach and not go down path of its got to be a big problem. Also you will always want to look at the last modification or repair done to bike to be sure it was done correctly. I wonder if video has been view for that in itself may correct OP concern and get him down the road running well.Hi David: Stupid(?) definitely not and especially on this site. We're all sitting on the same bench and have been there, asked that. O.E. or O.E.M. stands for Original Equipment or Original Equipment Manufacturer. The best in remedying your situation and you will get answers soon from the guru's as you've already seen from dbmg.
