Matt0987
I am thinking about having the low beam on with the high beam.
I have looked at the passing light detail to have the passing lights on with the high beam.
http://www1.hdtimeline.com/tn634s3.jpg
Essentially one simply disconnects the passing lights power feed from the low beam power feed and then takes the passing light power from the accessory circuit.
Now I am wondering how to have the low beam on when the hi beam is on. I do not like how you lose the low beam flooding the road immediately in front of the bike when the high beam is switched on.
I suppose I could do the same thing with the low beam as with the passing lights diagram. Simply disconnect the low beam feed and get the low beam power from the accessory circuit. By-passing the hi/low beam switch.
However, then I would be loading the accessory circuit with the passing lights and the low beam light. I would like to leave the accessory circuit available for other things. Such as my ham radio when I get it set up.
Is there a way to run the low beam and passing lights as they are now and simply have the hi/low switch turn off and on the hi beam so that the hi beam runs with the low beam and the passing lights? Keeping everything on the light circuit as it is now?
By the way Dads, Happy Father's Day !!!!!!!
