ironmark
Junior Member
I noticed that the readings on my Dakota Digitals gauges have been showing that I am having what I would consider high oil pressure, when the engine is at running temp the oil pressure is at 17 to 20 PSI at a idle and when the bike is running 1500 RPM and above the oil PSI is 40 to 42. Also when riding at 70 to 80 MPH (around 2800 to 3000 RPM) the engine temps will range between 245 to 260 which I consider average when it is 75 degrees outside. The oil temps will get up to and hold at the same temps as the engine, for example= when the engine temp is 255 degrees the oil will climb to 255 degrees as well, I consider this to be to high for the oil temps. I do have the HD oil cooler on the bike which has the thermostat so I am wondering if the thermostat went out in the oil cooler housing and that is what is causing the oil pressure and temps to rise or could it be something else.
