skizman Active Member Jul 5, 2016 #1 Hello boys n girls! The air cleaner cover on my 02 Road King says Screamin Eagle. How can I tell if maybe the jugs are from a Screamin Eagle package? Exhaust pipes are not....they're fishtails. Your input is surely appreciated!!! Thanks.
Jeff Klarich Experienced Member Contributor Jul 5, 2016 #2 If the jugs are SE it will stamped on them.
J Jack Klarich Guest Jul 6, 2016 #4 The heads are stamped, the cylinders used to have a stamping on the top where the head gasket surface is
skizman Active Member Jul 8, 2016 #5 Jack Klarich said: The heads are stamped, the cylinders used to have a stamping on the top where the head gasket surface is Click to expand... Thanks Jack! Pretty obvious with the stickers. Not on mine. That's ok. I'm really happy with the stock power that my engine has.
