On fuel injected systems is there a way to adjust idle speed or is that totally computer done. Tfi installed and ac and v&h pipes, just seems to be idling high and I checked cables I guess I need to get a Tach.
There was a bulletin a while back that it seemed the problem for the higher idle on the FBW bikes was the fact that people were rolling on the throttle while shutting the bike down and thus the reason for the higher idle on a restart. Using the run switch to shut it off just eliminates the load from the ignition switch which over time would give a bit of an arc when the circuit is broken and could cause burning of the contacts in there.
Glider, that is interesting. I hadn't heard that before and it makes sense. I am going to have to learn to use the ignition switch only and leave the run switch in run position. Thanks.
