free website stats program ignition switch | Harley Davidson Forums
ignition switch
In that other post, reply #7 he removed the sticker that says lock/run/acc and found screws holding it in.
You have to remove the outer fairing for access to the back side of the switch. You may have to pull the radio, I don't recall, and the manual only mentions the removal of inner and outer fairing. Any who there is a pin under the lip of the instrument support housing. You pull this pin with needle nose pliers which will release the Knob.
If you can get your hands on a manual it would really help you.
tourbox
