How hard is it to change the gasket for an inner primary seal leak on a 2002 fxdl? The leak in not bad but after a couple of hours it will leak a little on the ground. A couple of drops. thanks
Thanks, for the info. That is the info I needed. I'll probably let it go for a while until it gets worse.
Could you elaborate on that? Where does the mist come out, and where does it show up 1st? Etc.OK, but check that it is not just that tranny vent tube blowing mist on the inside of your inner primary! I chased a bunch of harder potential problems before figuring it out!!
Thanks,
Rich P
Thanks,
Rich P
