R.Bingham
Last weekend I changed out my cams to the Andrews 21G gear drive cams. I finally got rid of the tensioners so I don't have to worry about that any more. My 6 1/2 year old daughter helped me do the job. ( Boy is she gonna make someone a great wife some day, can cook and work on Harleys )
To get the old cams out and press the new ones in I used the oven/freezer method. Since we homeschool this also made for a great science project. I was able to show her what the effects of heat and cold can have on objects.
Well now that the job is done I can say that I'm very pleased with the cam selection. It now pulls better at all rpms, goes through the gears a little bit faster and is definitely quicker.
I went with the gear drive instead of the conversion cams because my crank runout was only .002. I also got a great deal on the cams because the were slightly used.
I did not have to re-map my ecm. I have the stage one download. I have not had any issues with popping or pinging.
I recommend this cam or the conversion 21N version to any with the old style tensioners considering and upgrade.
Randall
Randall
