Installed the QD kit on my '11 FLTRU today, pretty simply to put on but I do have a couple of observations. Purchased HD part #53246-09A and HD part #69200181.
1) I went with the J&M antenna for the CB and radio in the fairing and removed the mast on the tour pak. That left me with two studs on the trunk I need to figure out how to cover.
2)Ordered the HD quick release (HD part #69200181) wire harness/antenna relocation recommended for the tour pak QD kit (HD part #53246-09A) on the ultra models. This was mostly the parts to move the antenna down on the fender and back to the tour pak...I really only needed the harness for the lights out of the kit but you can't get it separately. I have an 12V accessory port in my tour pak but there isn't anything in the kit for me to make it quickly detachable.
I'm going splice/extend the wiring inside the tour pak for both the lights and 12V accessory port, have both exit the tour pak and plug into the main harness under the seat.
IMO if you are going to move the antenna inside the fairing there really isn't a need to purchase HD part #69200181. If someone would like the antenna relocation stuff out of the kit let me know and you could have it for cheap.
