free website stats program Installing 5" Analog Speedometer | Harley Davidson Forums
Larrymcc1
Following the instructions for installing H.D. Analog Speedometer/Tach using the data link connector I plugged the speedometer into the data link as per the instructions and turned the ignition switch to on. It showed check on the screen, but as I stupidly forgot to bring the key fob into the garage the alarm stated screaming. I turned off the ignition and got the fob. Returning to turn the switch to on the speedometer, but only a red light went on. It does not appear to download data now. Need some help getting the speedometer to download data. Thanks in advance.
You need to check for codes, it may have thrown one when you tried the ignition without the fob.
