free website stats program Installing Mini Apes | Harley Davidson Forums
cyborg
Got everything to install my mini apes. Pulling the wire through the bars, Do I take the Black Casing off the wires or pull them through with it on the wires??:small3d007:
I would bet that you want the casings on the wire to protect harness.
If they'll fit through with the casings on then I'd definitely leave them that way.
The more insulation you can keep on them, the better. Make sure the holes are deburred, and use something to lube the sheath/cover. I don't know how you are doing the connections, if cutting & soldering make sure you stagger joints so you don't end up with a LUMP.
I saw somewhere that you can drop a small piece of chain in the bars to help pull the wire through the bars. It will go right around the bends by shaking the a little.It was one of the guys that makes bars. He had a short vid on how to do it. But I can't seem to find it.
Did mine with the casings on. Use LOTS OF LUBE............don't forget to post some pics when you're done.
