If you have the kit that Jack posted in #2 above, it should just be an easy install. If you are having problems, then check the instructions again and walk through each step to make sure nothing has been overlooked. This is the set I used to replace the air temp. gauge on my UC, and it was a very simple swap out.
Cheers,
