bus driver
I have a stock 91 EVO- EGC. My questions are, how loose should my intake manifold seals be? While reinstalling my CV carb, I noticed movement with the seals on the intake where they seat to the head. The intake moves fairly easily. There is some resistance, but I would think it should be fairly snug. My next question is, I seem to have a sticky float. My tank filter is clean, my inline filter is clean,and the fuel coming out of the fuel line is clean. I rebuilt the carb with a Made In The USA kit. But I still get a sticking float. Both open and closed position. When I rebuilt it, I soaked it in carb cleaning solution and blew out the carb with air. The rod that holds the float moves very freely and I am able to push it out with my finger. My float moves freely also. My tank is slightly rusty, but all of my fuel "appears" clean to the naked eye. I run Sea Foam and Marvel Mystery oil. I'm scratching my head and it's starting to hurt. P.S. 30,000 miles on the odometer. P.S.S. The float doesn't stick with the carb apart, go figure. Thanx Bus Driver.
