free website stats program ION Sensing Explained | Harley Davidson Forums
glider.
BOT Machine
More commonly known as knock retard.
First ION knock detection is the direction most applications are going to use. The old PEZIO sensor relied on a vibration ( caused by some level of knock ) to register at the sensor, It is very hard to detect low levels of knock and separate the signal ( knock from detonation ) from normal engine vibrations, such as valve closings on a Harley engine. On most vehicle applications the knock sensor can sense true knock from noise, but may not READ every cylinder in a multi-cylinder engine at every cylinder at every RPM, But most system use a GLOBAL retard scheme where any knock will retard spark to all cylinders at the same amount. New systems are going to individual cylinder knock detection where only the cylinder producing knock is retarded and only until knock ( detonation stops) so in a V8 or V6 you might only have one or two cylinders with any amount of retard.
The advantage of the ION system is it is not dependent on a sensor location and it can be calibrated to detect each cylinder at all engine speeds and loads.
ION sensing knock detection does not use a Sensor that is externally mounted on the engine. The name ION sensing is derived from the fact that as detonation happens IONIZATION at the plug tip changes the resistance to fire the plug. The actual detection to this change in resistance is internal to the coil and the signal is sent back to the ECM. Software tables are then calibrated using model based software. The way it is calibrated is important to understand WHY some folks are having TROUBLE. A very sophisticated Combustion measurement system is placed on a development engine and actual cylinder pressures are recorded vs. crank angle degrees and coil operating ranges, as the engine is running at set speed and loads. By reading "NORMAL" outputs from the ignition module electronics to the ECM input and noting the change when detonation causes Peak cylinder pressures to rise, a model can be developed that as long as the signal from the ignition module is outputting the "expected NORMAL" signal back to the ECM no retard will occur. A change in resistance value and amount can be correlated to a given rise in pressure in the chamber during combustion.Detonation causes very large spikes in pressure even at very low levels of detonation, so the model can and does detect even before "audible detonation ( that that can be heard ) happens. It is a very good system and very reliable with one HUGE exception. Detection is dependent on the values calibrated in the software that represent knock, and are based on a stock engine ( or a known modified engine such as the STAGE I,II etc.) with a GIVEN set of Production intent parts.ie , Spark plugs, wires, and even compression ratio can and does change the resistance at the coil. So once folks start changing wires, Plugs ( to non-factory specs) and modifying the engine cams, compression ratio etc,( and even expected A/F ratios, and therefore combustion temperature) the values derived form a production engine are no longer valid and may cause the software to "determine" that knock is present when it's not or fail to detect knock when it is.
Just as production vehicles such as cars and trucks use similar schemes for many functions but most folks don't change parts or "hop-up" current cars with fuel injection systems... As an aside most people really don't know that if you change the air cleaner system or duct work ,even with a MASS AIRFLOW sensor you change the output of the mass airflow sensor. Those sensors are calibrated to read correctly only with a known set of induction parts. There is some amount of adaptability in the fuel system but it is possible to get even a closed-loop system, to where the software cannot adapt enough for some changes that one might make. EXHAUST, intake etc.
So Harley knock detection is really not that different than other vehicle manufactures, it's US the users that may not understand the impact on a calibrated system when making major or even minor changes. The STAGE flashes are calibrated to work correctly ONLY with very specific parts. One open exhaust or air cleaner is not the same as another of a different brand.... THE LEARNING CURVE will be steep and there is a lot of mis-information floating around.
Also see this post by "Hoople"...
Some Theory on Ion Knock Sub-System - Harley Davidson Community
Also look here for an in depth explanation...
Delphi Ionization Current Sensing Ignition Subsystems
Mr. Data, does the application of a TFI interfier with the anti knock device as suggested when you change A/F ratio?
No, the tfi only changes the pulse width of the injectors and doesn't interfere with other sensors. The ION sensing operates through the secondary voltage to the plugs.
good. the way it read i thought maybe something that changed any of the values out of the stock configuration might cause a faulty reading. at any rate my bike runs way better with the TFI that i don't care that if what it's reading is not valid.
What causes the system to be disabled? Do after market plugs have different resistance values that are out of spec and then disable the system or is it something else?
Alan
It is a feature of the ECM firmware that can be disabled or enabled using the SE super tuner software. HD plugs (6R12) do have more internal resistance (~20K-35K) than aftermarket crosses. I have used standard 5K plugs on my bike and did not see any change in the knock retard threshold or its characteristics.
Has anyone measured the signal from the Coil to the ECU with an oscilloscope?
It is the Grey/Blue cable from the two coils.
Would be interesting if it is a voltage from the shunt in the ION-Sense circuit.
