free website stats program JAGG horizontal or vertical cooler | Harley Davidson Forums
Spade5
I have made up my mind to install a Jagg oil cooler but cannot decide between the 6 row veritcal or the 10 row horizontal.
The 10 row seems be be less visible but I wonder about it picking up debris from the road. It seems that dirt would reduce the efficiency and a hard object might cause a leak.
Also - has anyone installed the anti-rotation device?
FWIW - you're installing an oil cooler because you feel your oil needs cooling. A 10 row should do a better job than a 6 row so the decision is a simple one - get the 10 row.
There's always the vertical mount that goes on the down tube and uses a foil to direct cooling air.
