free website stats program JAGG oil cooler | Harley Davidson Forums
JAGG oil cooler
Gabbin
Does anyone know what the fan switch should ohm out at? I'm getting no reading?:(
I fear I may have damaged it during the install of the cooler, when I tied in to the brake switch, I blew the accessory fuse.
It's a simple switch, its either open or closed. Reading across the pins with an ohm meter its either 0 or switch closed, infinity or switch open. The possibility exists that the one pin or the other is going to ground and that would be one lead to a pin and the other to the side of the switch, then the other pin to the side of the switch. An y reading at all here is voltage going to ground = bad news.
Well, that was the case, I replaced the fan switch with a 180* switch, since the oem was damaged. It runs perfectly. Thanks Bro!
