I was getting oil leakage from the filter cover blowing back over my clothes after a long ride at turnpike speeds. Not a lot only annoying. The bottom of the filter was dripping oil coming from the cylinder head vents. I made a tee out of two 1/4" OD pieces of stainless tubing welded together and attached the tee to the vents with two 90 degree pre-bent 1/4"rubber hoses tie wrapped to the breather vents. The hoses held the tee up and the other end lay in the intake. all the oil gets sucked in the intake as I thought it should do. I've put on a couple of thousand miles and did not use any oil or notice any milage change.
Do you guys think the oil going into the intake directly will cause any problems?
Thanks
Thanks
