harleymanmn
When I turn on the fuel valve, I get fuel dripping from bottom of valve body and it does not appear to be at fuel line connection. The fuel quits leaking when I shut off the valve. What could be the cause?
If this is a stock vacuum operated petcock, you may want to consider an up grade to a Pingel, seems to me there were no parts available for rebuilding those pesty petcocks
