With stock forward lights, the aux lamps are off when switching the headlamp to high beam. Since the LED lights pull less juice, is there a mod I can do so the aux lamps stay on?
You can also swap the yellow & orange/red wires in your harness...it's under your switch cover, on Right side of bike. Just turn handlebars to lock position & look under cover near top of frame (near VIN stamp), pull down the connector, disconnect & flip/flop the yellow & orange/red wires. All you need is large safety pin to flip the little connector catch.
