Yes it is a clatter not just ticking. My dealer says it's normal for a 103. I will bring it back to the dealer and see what they can do.
Can a lifter that leaks down cause any damage?
Thanks for your reply's
Jim
Jim,
Yes, the noise you hear is metal to metal (hammering) and not good but many lifters can do it for a long time with no real problem...
IT CAN Take out a Roller bearing in the bottom of a lifter though.....
OR flat-spot a cam(over time)
What cam do you have in your 103"
I use the SE255's in my 103" and I do not have a problem... Gaterman lifters... SE slender tapers adjustable PR's...
BUT like I said, I used the Lower portion of the lifter pre-load and Might be why mine are quiet.
I don't think it would have anything to do with 103" Other than the cams used... (Cow Bellar noise from HD Dealer)
IF you don't get satisfaction from your Dealer,,,,,Get a second oppinion from another... And OR ASK some of your friends or riders that have the same bike and see IF they have that Lifter Noise noise....
Usually a synthetic will allow More noise in an engine but using it
may FILL that noisy lifter sooner than the Dino oil.
Use a good synthetic,,,,
Not a Snake oil IMO....
Redline 20/50 is a good if not one of the best...
