The lights are on a 15a fuse. The box is behind the left side cover, and has a diagram on the fuse box cover. Check the Kuryakyn module, my friend's was getting pinched when he sat on the seat, causing fuses to blow.
jack checked the fuse was blown changed it lights now working but the bike wont stay running now starts up but dies fuel pump is working but checked the fuse under the right side cover anyway its fine what the heck did i do ?????
not sure what it was jack but there was and old kuryakan colored accent lighting system that was on the bike when i purchased it wasnt working and some where falling off so i took the opportunity to remove it while everything was apart everything else looked good so i fired it up and the darn thing runs fine but i did find a couple of modules under the seat that look like they may have been for a heated seat so i may take them off as well and that would leave lots of room for the kuryakan brake light module thanks for your input
