One For The Road
Hi,
I just bought a 2005 Ultra Classic. I have a couple of questions the smart people on here may be able to answer.
I plan on doing my own oil changes. The filter is mounted in front of the engine and is horizontal. I am wondering how much oil spills out when it is removed. I don't want to get oil all over the frame and electrical regulator mounted under it. If it tends to make a mess I can put some aluminum foil under it to help direct the oil into a container. Also, do you use a regular oil filter wrench to get it off or should I buy the 'special' wrench called for in the HD owners manual. Coming from Harley I'm sure it has a special price as well.
My other question concerns the exhaust. The PO put on an aftermarket exhaust and it is LOUD. I looked up inside the pipes and they have perforated metal baffles. I don't know who made the exhaust but it is a true dual exhaust system ... no crossover pipe. Any ideas on how to quiet it down a bit. I don't mind some exhaust note but not so loud that I can't hear the radio. How about removing the baffles and wrapping them with some type of fiberglass packing. If it helps I could post a picture of the pipes.
Thanks for your input and I am sure I will have more questions.
Steve
Steve
