When I pull the clutch in I get a very loud whine. Only when the bike is moving. Its a 02 WG. 5 speed, stock trans. I put new clutches in about 20,000 miles ago and have no problems with that. Shifts good. Clutch feels adjusted ok. Compensator looks fine and tight. Chain is adjusted. Sounds like its coming out of the primary side. I did look in their and found nothing wrong. Thinking may be in the trans main shaft bearing? Don't know were to go from here. Don't want to take it in. If I could figure out what it is I think I can fix it. Need help! Clutch in noise, Clutch out no nose.
