lqdesertrider Member Nov 5, 2008 #1 Any suggestions for best way to do it and any special tools or type of lube
G glider Veteran Member Nov 5, 2008 #2 The adjustments should be covered in the service manual and also in the self help forum, As far as what lube, take a look here. Clutch Cable/Handle Lubrication - Harley Davidson Community
USMCCWO5 Junior Member Nov 6, 2008 #3 This is what I use and can of cable spray lube. Picked them both up at the local Cycle Gear shop.:coffee Attachments cableluber.jpg 11.8 KB · Views: 51
krikket Active Member Nov 16, 2008 #4 USMCCWO5 said: This is what I use and can of cable spray lube. Picked them both up at the local Cycle Gear shop.:coffee Click to expand... I've seen those, but I don't see how they work. Could you explain?
