free website stats program Master cylinder question??? | Harley Davidson Forums
Is a 99 wide glide master cylinder, the same as a 03 super glide master cylinder???? Or could the wide glider master cylinder maybe a higher volume or something!!!! It doesnt seem that I am getting enough pressure in my 03 master cylinder to my 99 wide glide caliper!!!! Does anyone have a clue????
The master cylinder on my 2000 electra glide is stamped 11/16. You should be able to see the size stamped on yours. If you have dual disc brakes on the front should be 11/16, if you have a single disc brake I believe that should be 9/16.
