Is that a threaded hole or a roll pin for locating the trap door? If the hole is threaded replace the bolt with the proper length with loctite and check torque on all bolts
Relax, as Jack and Tourbox said no bolt belongs in that hole, or the matching one directly across from it. There is a picture in the service manual if that helps to ease your mind.
