Purchased an independent control auxiliary lamp wiring kit for my 2012 FLHR. Started the install last evening. Split the nacelle to get to the auxiliary lamp toggle switch. Followed the .pdf instruction provided with the H-D kit and opened up the switch and removed the middle spade to connect to the wiring kit.
Then all stop. DIW! The .pdf is off the chart with what I'm suppose to do next. Now, I need help from you guys that have installed this kit on your FLHRs.
Pictures would also help. I seem to remember that sometime back, I found a DIY with photos of the kit in one of the forums when it was first introduced some years ago. Cannot find that post anymore. It was sometime in 2009 I think.
Anyways, whatever tech assist will be highly appreciated.
Thank you.
Thank you.
