I have the same problem, very poor hearing. On my new '09 electra glide classic, i had to turn my completely stock sound system almost all the way up on the highway just to hear most of what was being played. I blew the left channel, low frequency driver out before the bike was 6 months old. I went and bought the j+m 7.25 inch, 3-way speakers off ebay. These sounded way better than stock and i paid right around $225 for them, they might be cheaper now. They are also claimed to handle more power which means i can and will add an aftermarket amp/eq, if i can find a 2-ohm stable piece. If not, i'll settle for a 4-ohm amp/eq. And just add resistors to the speakers. I want the eq to tweak out that boxey sound that these speakers seem to have. I felt $225.was very pricey for stamped steel frame, chinese made speakers, but they look nice and sound nice and in the end i didn't have to do a lot of hit or miss research fitting other aftermarket speakers. The stock speakers are also 2 ohm just like the j+m's. Good luck finding 2 ohm car speakers.the lower the ohms the louder the music will sound. But it places a heavier load on the amp. If you intend to use an amp or booster/equalizer with the head unit, be careful, some aftermarket car amps will run hot or burn up at 2 ohms. The j+m's also come with a black grill that has a silver tweeter and silver midrange in it, one for each side of course. One special part included is a set coupling adapter rings to go from the stock 5.25 inch to the 7.25 inch j+m, i looked for this ring by itself on the internet and couldn't find it. I found some that adapted 6.75 inch speakers. This allows you to use any automotive speakers you wish as long as they are not too big[deep] which would prevent you from getting the fairing back together. The j+m speakers were descibed in the various reviews i read, as being "boxey sounding" this was what i heard as well. Long story short it is now better sounding and i can hear it a little better on the highway. I still have to crank it but soon i intend to put a pyramid 506vl booster/equalizer in the fairing. I'll tweak this to get rid of that boxey sound and than hide it in the fairing. I'm not sure if the pyramid is 2-ohm stable so i may need to add resistors to the speakers, no big deal. I just don't want my fairing to start on fire out on the highway. These are not audiophile grade components but at the same time i'm not sitting in my front room listening to a $10,000 hi fi system.
