Have you changed out the switch covers on bars???? if so possibly broken pin on front brake switch. If not then check connector at rear master cylinder to make sure attached properly.
This may help. Click on link: Rear Brake Light Switch - Harley Davidson Community
Cruise will not engage with brake light staying on..
How about the famous rear brake switch. Mine just went and brake lights will not work, but I've hear they can also get stuck so the brake light is always on.
bike is 2010 street glide screaming eagle 103, no mod on bars i bought it used and guy that owned it had some workdone but mostly just chrome covers no real modifications
If he had chrome switch covers put on the handlebar switches, the problem is most likely with the hand brake on the bars, as someone mentioned earlier.
